I am running into a couple of odd things. My RT-AC86U seem to be working relatively OK (can browse the internet via VPN, access my LAN (and solidly after 4 years), but it has been acting a little funny. My internet kept dropping 1-3x daily the past few days.
When I run amtm and select 'u' to check for script updates, I am receiving this message:
" pkg_get_installed_files: Faily to open //opt/lib/opkg/info/p7zip.list: Input/output error. "
When I navigate to that directory, I do NOT see any such file. Does any one know how to restore "p7zip.list"? Do I even need p7zip? I'm not sure if there are any other of the packages depends on p7zip...
I tried to create a file with by that very name using 'nano' but I get an error:
I tried:
Which gives me the same message:
"Collected errors:
* pkg_get_installed_files: Failed to open //opt/lib/opkg/info/p7zip.list: Input/output error."
I then tried:
Which gives me this:
"Installing p7zip (16.02-3) to root...
Downloading https://bin.entware.net/aarch64-k3.10/p7zip_16.02-3_aarch64-3.10.ipk
Collected errors:
* pkg_write_filelist: Failed to open //opt/lib/opkg/info/p7zip.list: Input/output error.
* opkg_install_pkg: Failed to extract data files for p7zip. Package debris may remain!
* opkg_install_cmd: Cannot install package p7zip."
On a different (maybe related?) note, it appears I may have some USB ext4 errors too. When I run this:
I get:
Please help!
I tried:
opkg install p7zip
"Collected errors:
I then tried:
opkg install p7zip --force-reinstall
Collected errors:
cat /jffs/addons/amtm/amtm-dsik-check.log
I get:
Please help!
