AMTM / RTRMON
bencehavran
Hello guys,
I have an ASUS GT-AX11000 router with Merlin firmware. I am using amtm on it and would like to use the rtrmon add-on within it.
Unfortunately, point 7 (Max 6GHz Speed (Mbps): N/A) is grayed out and I cannot set it. When I try to do so, I get the message "This item is currently only available for router models: GT-AXE11000 and GT-AXE16000. Exiting..."
ist it possible to force it to use ax11000 settings?
merlin 388.2
rtrmon v1.54
thank
bence
Thank you. In the tech specs, it was mentioned as Wifi 6, which can be a bit misleading, as it doesn't mean 6 GHz.
@Viktor Jaep Typo: It's GHz not Ghz. If you want to be really pedantic there ought to be a space between it and the number in front of it (even though I usually omit it myself :)).
Oh jeez... you are absolutely correct. Sorry about that - I'll make that correction... :p
EDIT: so the nomenclature was correct on the rest of the screens, except for this setup screen. Oopsie. Thanks for the catch. ;)
It can be a stumbling block for many... ;)
