annoying interface issue on 1440p resolution( Firmware:380.65_4 )
Safa
i dont really know how to explain this so i'm just going to upload a screenshot.
when i make the browser window smaller, it goes back to normal. so i guess its because of the 1440p resolution on my display.
Known issue (there are other posts with the same screenshot :))...only workaround is to reduce the window size as you have found.
OR adjust your Zoom to anything other than %100. I found %110 works fine (for whatever reason)
Seems to be a chrome thing.
Ok, thanks. i tried searching to see if anyone else had the same problem but i didn't know what to search for!
yes, its a chrome thing. it looks fine on other browsers. zooming seems like the best option.
