Hi All,
Not a Merlin specific question, but I figure you guys are the experts on Asus routers
I recently got a 1000/100 fiber connection, and my 87U running Merlin can't quite keep up.
To clarify, I have: Fiber connection -> TP link media converter -> 87U lan port. So the router is handling the PPPOE connection.
Without QOS enabled, I can pull around 850 down, at which point the CPU maxes out.
With QOS enabled, the cpu maxes out around 500 mbps.
Could the new 86U with the 1.8 ghz CPU handle Gigabit with QOS enabled? Or is this just not realistic with a consumer router?
Or am I doing something wrong here that's chocking the router? I do have NAT / CTF set to auto... That's the only thing I could think of. No VPN running, most other things are default on the router. Tried 1492 / 1500 MTU, doesn't really make a difference.
The router provided by my ISP can handle gigabit fine (no qos) with almost no CPU load. Seems odd the Asus can't handle it.
Thanks!
Thanks!
