amtm Any IP restrictions to access diversion.ch and scripts ?
blach
Hello
I'm located in Morocco.
When I try to install or run some scripts or tools using AMTM on my Asuswrt-Merlin device, I get errors related to download failures.
Same when I open https://diversion.ch/ in my Chrome browser : ERR_CONNECTION_TIMED_OUT
Both work as intented when I use a VPN to change my location. Are there any IP / Geo restrictions to access diversion.ch and others required urls?
Regards
Have you cleared your browser cache, Ctrl - F5?
Some countries/ISPs block certain sites for "security" reasons. Try setting your DNS to quad9.
I first ran into the issue in the router shell. It's not related to my browser's cache
In Shell:
1) AMTM run "uu" for reinstall of AMTM, then next
2) Diversion, option 1: run "u" , force reinstall.
If they both complete, then the scripts are running OK and the problem is someplace else, related to router settings.
Also, Entware just released an update today:
Do that update first "ep", then do the above.
Without VPN I can resolve the diversion.ch A-Record but I can't ping the associated IP address nor access it :
4dmin5T6m@RT-AC87U:/tmp/home/root# nslookup diversion.ch
Server: 1.1.1.1
Address 1: 1.1.1.1 one.one.one.one
Address 1: 80.74.145.140 emerson.ch-meta.net
4dmin5T6m@RT-AC87U:/tmp/home/root# wget diversion.ch
--2022-12-19 14:16:12-- http://diversion.ch/
Resolving diversion.ch... 80.74.145.140
Connecting to diversion.ch|80.74.145.140|:80... failed: Connection timed out.
I'm pretty sure it is configured on the server.
In Shell:
Without VPN all commands return connection failed
