Any luck with OpenVpn?
ozgurcnbyz
Hi i have a fiber optic internet connection at home which is 50/5. A cat6 cable is connected to the isps Huawei routers wan port. Unfortunately theres no luck configuring bridge mode or replace huawei with my asus rt-ac66u. Instead of running in AP mode i connected both routers back to back and let the wifi and dhcp handled by asus. So this is basically a double nat situation. I was wondering if its still possible to run vpn client on the asus router. I setup an openvpn server in a Vps and its functional. All i really want to do is selective routing to access geo restricted content
Sent from my iPhone using Tapatalk - now Free
Clients are outbound, so there's no port forwarding required, and it won't be affected by double NAT. Only if you were running a server.
I assume you are using Superonline for your internet connection. You can replace Huawei router with the AC66U, if you can get a hold of your ISP account and password from them and then directly connect to CAT6 cable to your AC66U WAN port.
Yes its indeed superonline. They wont tell me my account info but i managed to get it anyway by texting a number. Really weird. Anyway i also have voip so i guess i cant just toss the huawei router. Do i need mac cloning aswell ?
If you got it via text, that is fine. You can use it. I don't have VOIP service, so I don't know how you can setup the service. There should be section for it maybe in ASUSWRT you can check.
I didn't do any mac cloning to use the internet. It was plug and play. :)
