Any MikroTik RouterOS Gurus?
jasons6930
Hi Guys,
For various reasons, i have had to reconfigure my Mikrotik 4011 from scratch.
I have managed to get it all up and running from various posts i have made before, however, i am having IPV6 issues.
For some reason, my firewall does not let ICMPv6 through, as when i use a test site it fails.
I have included my current config, and im wondering if anyone could have a look and see where i may have gone wrong, or anything i have missed.
Cheers!
set [ find default-name=ether1 ] comment=Internet
/interface ethernet switch port
set 0 default-vlan-id=0
set 1 default-vlan-id=0
set 2 default-vlan-id=0
set 3 default-vlan-id=0
set 4 default-vlan-id=0
set 5 default-vlan-id=0
set 6 default-vlan-id=0
set 7 default-vlan-id=0
set 8 default-vlan-id=0
set 9 default-vlan-id=0
set 10 default-vlan-id=0
set 11 default-vlan-id=0
/interface list
add comment=defconf name=WAN
add comment=defconf name=LAN
/ip pool
add name=dhcp ranges=192.168.88.10-192.168.88.254
/ip dhcp-server
add address-pool=dhcp disabled=no interface=bridge lease-time=1d name=defconf
/ipv6 dhcp-server
add address-pool=Pool1 interface=bridge name=server1
/ipv6 pool
add name=pool1 prefix=::/64 prefix-length=64
/user group
set full policy="local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,pas\
    sword,web,sniff,sensitive,api,romon,dude,tikapp"
/interface bridge port
add bridge=bridge comment=defconf interface=ether2
add bridge=bridge comment=defconf interface=ether3
add bridge=bridge comment=defconf interface=ether4
add bridge=bridge comment=defconf interface=ether5
add bridge=bridge comment=defconf interface=ether6
add bridge=bridge comment=defconf interface=ether7
add bridge=bridge comment=defconf interface=ether8
add bridge=bridge comment=defconf interface=ether9
add bridge=bridge comment=defconf interface=ether10
add bridge=bridge comment=defconf interface=sfp-sfpplus1
/ip neighbor discovery-settings
set discover-interface-list=LAN
/interface detect-internet
set detect-interface-list=all
/interface list member
add comment=defconf interface=bridge list=LAN
add comment=defconf interface=ether1 list=WAN
/ip address
add address=192.168.88.1/24 comment=defconf interface=ether2 network=\
    192.168.88.0
add address=159.xxx.xxx.xxx/30 interface=ether1 network=159.xxx.xxx.xxx
/ip dhcp-client
/ip dhcp-server network
add address=192.168.88.0/24 comment=defconf gateway=192.168.88.1
/ip dns
set allow-remote-requests=yes cache-max-ttl=1d servers=\
    1.1.1.1,2606:4700::1111,1.0.0.1,2606:4700::1001
/ip dns static
add address=192.168.88.1 comment=defconf name=router.lan
/ip firewall filter
add action=accept chain=input comment=\
    "defconf: accept established,related,untracked" connection-state=\
add action=drop chain=input comment="defconf: drop invalid" connection-state=\
    invalid
add action=accept chain=input comment="defconf: accept ICMP" protocol=icmp
    "defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=drop chain=input comment="defconf: drop all not coming from LAN" \
    in-interface-list=!LAN
add action=accept chain=forward comment="defconf: accept in ipsec policy" \
    ipsec-policy=in,ipsec
add action=accept chain=forward comment="defconf: accept out ipsec policy" \
    ipsec-policy=out,ipsec
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" \
    connection-state=established,related
add action=accept chain=forward comment=\
    "defconf: accept established,related, untracked" connection-state=\
add action=drop chain=forward comment="defconf: drop invalid" \
    connection-state=invalid
add action=drop chain=forward comment=\
    "defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat \
    connection-state=new in-interface-list=WAN
/ip firewall nat
add action=masquerade chain=srcnat comment="defconf: masquerade" \
    ipsec-policy=out,none out-interface-list=WAN
/ip route
add distance=1 gateway=159.xxx.xxx.xxx
/ipv6 address
add address=2a00:xxxx:yyyy:1::1 interface=bridge
add address=2a00:xxxx:yyyy::2 interface=ether1
/ipv6 firewall address-list
add address=::/128 comment=defconf:lo list=badipv6
add address=fec0::/10 comment=site-local list=badipv6
add address=::/128 comment="defconf: unspecified address" list=bad_ipv6
add address=::1/128 comment="defconf: lo" list=bad_ipv6
add address=fec0::/10 comment="defconf: site-local" list=bad_ipv6
add address=::ffff:0.0.0.0/96 comment="defconf: ipv4-mapped" list=bad_ipv6
add address=::/96 comment="defconf: ipv4 compat" list=bad_ipv6
add address=100::/64 comment="defconf: discard only " list=bad_ipv6
add address=2001:db8::/32 comment="defconf: documentation" list=bad_ipv6
add address=2001:10::/28 comment="defconf: ORCHID" list=bad_ipv6
add address=3ffe::/16 comment="defconf: 6bone" list=bad_ipv6
add address=::224.0.0.0/100 comment="defconf: other" list=bad_ipv6
add address=::127.0.0.0/104 comment="defconf other" list=bad_ipv6
add address=::/104 comment="defconf: other" list=bad_ipv6
add address=::/4 comment="defconf: other" list=bad_ipv6
/ipv6 firewall filter
add action=accept chain=input comment="defconf: accept" connection-state=\
    invalid
add action=accept chain=input comment="defconf: accept ICMPv6" \
    connection-state="" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
    33434-33534 protocol=udp
    "defconf: accept DHCPv6-Client prefix delegation." dst-port=546 protocol=\
    udp src-address=fe80::/16
add action=accept chain=input comment="defconf:accept IKE" dst-port=500,4500 \
    protocol=udp
add action=accept chain=input comment="defconf: accept ipsec AH" protocol=\
    ipsec-ah
add action=accept chain=input comment="defconf: accept ipsecESP" protocol=\
    ipsec-esp
    "defconf:accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=input comment=\
    "defconf: drop everything else not coming from LAN" in-interface-list=\
    !LAN
add action=drop chain=forward comment="defconf: Drop Invalid" \
    "defconf: drop packets with bad src ipv6" src-address-list=bad_ipv6
    "defconf:drop packets with bad dst ipv6" dst-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: rfc4890 drop hop=limit=1" \
    hop-limit=equal:1 protocol=icmpv6
add action=accept chain=forward comment="defconf: accept ICMPv6" protocol=\
    icmpv6
add action=accept chain=forward comment="defconf: accept HIP" protocol=139
add action=accept chain=forward comment="deeconf: accept IKE" dst-port=\
    500,4500 protocol=udp
add action=accept chain=forward comment="defconf: accept ipsec AH" protocol=\
    ipsec-ah
add action=accept chain=forward comment="defconf:accept ipsec ESP" protocol=\
    ipsec-esp
    "defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
    !LAN
/ipv6 nd
set [ find default=yes ] advertise-dns=no advertise-mac-address=no interface=\
    bridge managed-address-configuration=yes other-configuration=yes
/ipv6 nd prefix
add autonomous=no interface=bridge prefix=::/0
/ipv6 route
add distance=1 gateway=2a00:xxxx:yyyy::1
/system clock
set time-zone-name=Europe/London
/tool mac-server
set allowed-interface-list=LAN
/tool mac-server mac-winbox
Hi Guys,
Cheers!
/interface list
/ip pool
/ip dhcp-server
/ipv6 dhcp-server
/ipv6 pool
/user group
/ip address
    192.168.88.0
/ip dhcp-client
/ip dns
/ip dns static
/ip firewall filter
    invalid
/ip firewall nat
/ip route
/ipv6 address
    invalid
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
    icmpv6
    ipsec-ah
    ipsec-esp
    !LAN
/ipv6 nd
/ipv6 nd prefix
/ipv6 route
/system clock
/tool mac-server
Jason, did you try the Mikrotik forum? I found it most helpful in the past.
Yea I did and we/I came to the conclusion that the particular website I was using for the test has some odd bugs.
I was able to ping in and out from various addresses and all was working fine.
I also used alternative test sites and they were coming back 100%.
The real oddity was the fact that iOS returned a full house but OS X and w10 didn’t.
Weird!
