I'm looking for a way to mount an nfs share on my NAS to my router. The reason for this being that the NAS is already overloaded with stuff and I've setup entware+chrooted debian on merlin's fw to run sonarr. Sonarr is just a grabber and organizer so no issues with downloading files to the NAS, just rename+move.
The issue is that I'm unable to mount the NFS share from my NAS onto my router automatically after boot. I can do it manually after boot, but I need to set it up to remount automatically.
So far I've tried:
1. Editing the /jffs/configs/fstab file and making it wait for network, but it doesn't work (I'm assuming because the NAS is connected to the router)
2. Adding a simple mount command to mount the share in the services-start jffs script but this doesn't work either.
Looking at the log, it seems like statd is loaded at the end, way after services-start, so it might be why the nfs mount fails. I need the mount command to be the LAST thing to run at the end of boot, which script should I put the mount command in? I tried a bunch of different script files like wan-start but, same results.
This works when mounting a samba share, but I want to get nfs to work.
Please advise, I'm still learning and new to this.
So far I've tried:
