All the models that I currently support have HFS+ support, through the Tuxera driver Asus licenced.
I just connected a HFS+ formatted drive to my RT-AC66U but it wouldn't mount. From the log (what I think is interesting is
highlighted)
Apr 6 20:52:56 kernel: usb 1-1.2: USB disconnect, address 3
Apr 6 20:52:56 rc_service: hotplug 1167:notify_rc restart_nasapps
Apr 6 20:52:56 NFS_Server: daemon is stopped
Apr 6 20:52:56 MediaServer: daemon is stopped
Apr 6 20:52:56 rc_service: hotplug 1177:notify_rc restart_nasapps
Apr 6 20:52:56 rc_service: waiting "restart_nasapps" via ...
Apr 6 20:52:56 FTP_Server: daemon is stopped
Apr 6 20:52:56 kernel: usb 1-1.2: new high speed USB device using ehci_hcd and address 4
Apr 6 20:52:56 Samba_Server: smb daemon is stopped
Apr 6 20:52:56 miniupnpd[459]: shutting down MiniUPnPd
Apr 6 20:52:56 kernel: hub 1-1:1.0: unable to enumerate USB device on port 2
Apr 6 20:52:56 miniupnpd[1191]: HTTP listening on port 36782
Apr 6 20:52:56 miniupnpd[1191]: Listening for NAT-PMP/PCP traffic on port 5351
Apr 6 20:52:56 kernel: usb 1-1.2: new high speed USB device using ehci_hcd and address 5
Apr 6 20:52:56 kernel: usb 1-1.2: configuration #1 chosen from 1 choice
Apr 6 20:52:56 kernel: scsi1 : SCSI emulation for USB Mass Storage devices
Apr 6 20:52:57 NFS_Server: daemon is stopped
Apr 6 20:52:57 MediaServer: daemon is stopped
Apr 6 20:52:57 rc_service: hotplug 1189:notify_rc restart_nasapps
Apr 6 20:52:57 rc_service: waiting "restart_nasapps" via hotplug ...
Apr 6 20:52:57 FTP_Server: daemon is stopped
Apr 6 20:52:57 Samba_Server: smb daemon is stopped
Apr 6 20:52:57 miniupnpd[1191]: shutting down MiniUPnPd
Apr 6 20:52:57 miniupnpd[1206]: HTTP listening on port 60704
Apr 6 20:52:57 miniupnpd[1206]: Listening for NAT-PMP/PCP traffic on port 5351
Apr 6 20:52:57 kernel: usb 1-1.2: USB disconnect, address 5
Apr 6 20:52:58 kernel: usb 1-1.2: new high speed USB device using ehci_hcd and address 6
Apr 6 20:52:58 kernel: usb 1-1.2: configuration #1 chosen from 1 choice
Apr 6 20:52:58 kernel: scsi2 : SCSI emulation for USB Mass Storage devices
Apr 6 20:52:58 rc_service: hotplug 1170:notify_rc restart_nasapps
Apr 6 20:52:58 rc_service: waiting "restart_nasapps" via hotplug ...
Apr 6 20:52:58 NFS_Server: daemon is stopped
Apr 6 20:52:58 MediaServer: daemon is stopped
Apr 6 20:52:58 FTP_Server: daemon is stopped
Apr 6 20:52:58 Samba_Server: smb daemon is stopped
Apr 6 20:52:58 miniupnpd[1206]: shutting down MiniUPnPd
Apr 6 20:52:58 miniupnpd[1227]: HTTP listening on port 60406
Apr 6 20:52:58 miniupnpd[1227]: Listening for NAT-PMP/PCP traffic on port 5351
Apr 6 20:52:59 rc_service: hotplug 1185:notify_rc restart_nasapps
Apr 6 20:52:59 rc_service: waiting "restart_nasapps" via hotplug ...
Apr 6 20:52:59 NFS_Server: daemon is stopped
Apr 6 20:52:59 MediaServer: daemon is stopped
Apr 6 20:52:59 FTP_Server: daemon is stopped
Apr 6 20:52:59 Samba_Server: smb daemon is stopped
Apr 6 20:52:59 miniupnpd[1227]: shutting down MiniUPnPd
Apr 6 20:52:59 miniupnpd[1232]: HTTP listening on port 51751
Apr 6 20:52:59 miniupnpd[1232]: Listening for NAT-PMP/PCP traffic on port 5351
Apr 6 20:53:00 kernel: usb 1-1.2: USB disconnect, address 6
Apr 6 20:53:00 NFS_Server: daemon is stopped
Apr 6 20:53:00 MediaServer: daemon is stopped
Apr 6 20:53:00 FTP_Server: daemon is stopped
Apr 6 20:53:00 Samba_Server: smb daemon is stopped
Apr 6 20:53:00 miniupnpd[1232]: shutting down MiniUPnPd
Apr 6 20:53:00 miniupnpd[1243]: HTTP listening on port 52654
Apr 6 20:53:00 miniupnpd[1243]: Listening for NAT-PMP/PCP traffic on port 5351
Apr 6 20:53:10 kernel: usb 1-1.1: new high speed USB device using ehci_hcd and address 7
Apr 6 20:53:10 kernel: usb 1-1.1: configuration #1 chosen from 1 choice
Apr 6 20:53:10 kernel: scsi3 : SCSI emulation for USB Mass Storage devices
Apr 6 20:53:12 kernel: scsi 3:0:0:0: Direct-Access Disk Name 0009 PQ: 0 ANSI: 2 CCS
Apr 6 20:53:12 kernel: sd 3:0:0:0: [sda] 976773168 512-byte hardware sectors (500108 MB)
Apr 6 20:53:12 kernel: sd 3:0:0:0: [sda] Write Protect is off
Apr 6 20:53:12 kernel: sd 3:0:0:0: [sda] Assuming drive cache: write through
Apr 6 20:53:12 kernel: sda: sda1 sda2 sda3 sda4
Apr 6 20:53:12 kernel: sd 3:0:0:0: [sda] Attached SCSI disk
Apr 6 20:53:12 kernel: sd 3:0:0:0: Attached scsi generic sg0 type 0
Apr 6 20:53:13 hotplug[1266]: USB /dev/sda3(hfs+j) failed to mount at the first try!
Apr 6 20:53:13 kernel: ufsd: use builtin utf8
Apr 6 20:53:13 hotplug[1275]: USB /dev/sda2(hfs+j) failed to mount at the first try!
Apr 6 20:53:13 hotplug[1269]: USB /dev/sda4(ntfs) failed to mount at the first try!
Apr 6 20:53:13 kernel: ufsd: use builtin utf8 instead of kernel utf8
The router is running
374.43_48E2j9527 (Merlin LTS fork)
Should this work?
The volume is a little special, screenshot from Disk Utility:
Two partitions, the first is HFS+, the second NTFS.
Physically it is a 2,5" mechanical disk from an old Macbook Pro, powered through USB (can my router provide enough power?).
