Any suggestions for chkwan.sh not found on RT-AC86U?
mdover
I'm trying to reinstall ChkWAN automated monitoring and it's not working. I had it installed, and then we had a 4 day power outage. Once power returned, no one was at the residence for another 3 days and the internet receiver was buried in snow, so it must have cycled the router off an on countless times.
When I got back to the premise, the router was in setup mode so many files and settings were erased but not all. I tried to reinstall chkwan but kept getting the error chkwan.sh not found when I tried to test the installation with ./ChkWAN.sh help
I figure something probably corrupted so I ended up resetting the router to factory and installing a six month old Asus stock firmware. Then I reinstalled Merlin with the latest stable release. I also formatted the JFFS partition. Then I reinstalled through the regular process. I can see the file in MobaXterm but when I try to check if its working properly with './ChkWAN.sh help' I get the response that the file isn't there. I've successfully installed this on two routers in the past and am using the same process, but it won't work this time.
Any tips on other things I can try? I've reformatted the JFFS partition for now and I'll just run without. If it seems I need something (as its a property that we don't live at full time) I'll get a wifi reset plug as this isn't working for me any longer. Probably best to have the plug anyways for the occasional extended outages like we just had. I don't think the script was really designed for that based on how the router responded.
Try the following commands
ls -l /jffs/scripts
sh -x /jffs/scripts/ChkWAN.sh once nowait
and post the output.
If errors are shown then reinstall ChkWAN
curl --retry 3 "https://raw.githubusercontent.com/MartineauUK/Chk-WAN/master/ChkWAN.sh" -o "/jffs/scripts/ChkWAN.sh" && chmod 755 "/jffs/scripts/ChkWAN.sh"
then retry the commands
