I have an RT-AC66U_B1 (384.15) router in a remote location - i.e. no one is there to power cycle it.
My devices in that location can connect to the router, but they can't get out to the internet anymore.
I cannot connect to the router thru https anymore (even if I could I doubt the reboot button would work)
but I can still ssh in and run commands.
I've tried scmerlin, and tell it to reboot the router; I've run "service reboot" (which is what scmerlin does);
I've tried "/sbin/reboot" and "/sbin/reboot -f" and nothing works.
If I look at what is in /tmp/syslog.log when I run /sbin/reboot -f I see
Mar 19 21:18:07 kernel: SysRq : Emergency Sync
but it doesn't reboot and stays up
Is there any other command to reboot the router?
In case anyone is wondering how the router gets in this state, I've seen this issue:
- The GUI System status screen shows 100% on Core 2
- top shows that it is not actual CPU usage on Core 2 (aka CPU1) but IO Wait
- ps shows that a large number of processes show "D" state (I assume that is Disk Wait)
(I think whatever process gets in this state is just an innocent victim, not the cause)
- In the current case I see 1040 of these
and now a number of other processes in "D" state
I've seen this now on 3 different RT-AC66U_B1 routers with 3 different software versions and 3 different usb sticks with 2 different file systems (once NTFS, twice ext4).
It's happens after the router has been up ~ 27 days.
Mem: 211672K used, 44004K free, 908K shrd, 432K buff, 6620K cached
CPU0: 0.3% usr 0.0% sys 0.0% nic 97.0% idle 0.0% io 0.0% irq 2.5% sirq
CPU1: 0.7% usr 0.9% sys 0.0% nic 0.0% idle 97.4% io 0.0% irq 0.7% sirq
Load average: 1003.14 927.47 290.28 1/1185 23074
PID PPID USER STAT VSZ %VSZ CPU %CPU COMMAND
21424 21423 bob R 1504 0.5 1 0.7 top
23004 23003 bob S 1476 0.5 0 0.1 {scmerlin} /bin/sh /opt/bin/scmerl
23002 200 bob S 1152 0.4 0 0.1 dropbear -p 2356 -s -a
263 1 bob D 23860 9.3 1 0.0 networkmap --bootwait
21431 1 bob S 6124 2.3 1 0.0 httpd -i br0
1278 1 bob S 6000 2.3 1 0.0 /usr/sbin/smbd -D -s /etc/smb.conf
1277 1 bob S 5796 2.2 0 0.0 /usr/sbin/nmbd -D -s /etc/smb.conf
393 1 bob S 5640 2.2 1 0.0 amas_lib
644 393 bob S 5640 2.2 0 0.0 amas_lib
1 0 bob S 5624 2.2 1 0.0 /sbin/preinit
194 187 bob S 5624 2.2 0 0.0 /sbin/netool
187 1 bob S 5624 2.2 0 0.0 /sbin/netool
195 194 bob S 5624 2.2 0 0.0 /sbin/netool
178 1 bob S 5608 2.1 0 0.0 /sbin/wanduck
12816 1 bob S 5604 2.1 0 0.0 bwdpi_wred_alive
271 1 bob S 5604 2.1 1 0.0 pctime
22926 1 bob S 5604 2.1 0 0.0 watchdog
270 1 bob S 5604 2.1 0 0.0 hour_monitor
21308 1 bob S 5604 2.1 0 0.0 usbled
302 bob 1424 D cp /tmp/syslog.log /tmp/syslog.log-1 /jffs
ps | grep D | less
1 bob 5624 D /sbin/preinit
11 bob 0 DW [sync_supers]
36 bob 0 DW [kworker/1:1]
97 bob 0 DWN [jffs2_gcd_mtd4]
205 bob 5092 D nt_center
263 bob 23860 D networkmap --bootwait
