Any way to save guest network settings?
paulgj
Hi there,
I might be missing something but is there a way to define a guest network (ssid, passphrase etc) and then disable, enable as desired?
I have petsitters come to my house on a regular basis and I have given them an SSID and password to use when they visit. Most of the time I have the guest network disabled but then I have to create from scratch for each of their scheduled coverage periods.
Not a big deal but would be nice to save the settings and then enable/disable as needed.
Thanks!
A crazy workaround might be with john9527's NVRAM save restore utility. ;)
