I'm trying to improve the range and signal strength of my AC-66u router. Due to the location of cable outlets in my house, I don't have the option of placing my router in the middle of my house, which would solve all my problems. So I'm trying to find other solutions that will allow my router located on one side of my house to reach all of the rooms on the far side of my house.
I'm thinking of buying these to improve my wi-fi range and reception:
http://www.amazon.com/dp/B00HMRJ8WK/?tag=snbforums-20
Anyone had any experience with these or a similar product before? If so, what kind of improvement, if any, can I expect to get out of these realistically speaking (as compared to the factory supplied antennas).
My other option is to buy a second router and some powerline adapters in order to place a second router in the middle of my house. While that may be the best solution, it's also going to be the most expensive solution. If I can get a good enough improvement for $20, I would rather go with that (if possible).
Thanks for any advice you can give me on the antennas in advance.
