Sorry.
I have posted the same question under "security" -> "vpn" and got no answer there.
But here goes
Router - RT-AC66U with Merlin's FW latest version.
VPN Provider - VyprVPN
followed the instructions for setting up OpenVPN Client -
- Set Start with WAN to Enabled.
- Set Interface Type to Tun.
- Set Protocol to UDP.
- Set the Server Address/Port to uk1.vpn.giganews.com and port to 1194.
- Set the Firewall to Automatic.
- Set Authorization Mode to TLS.
- Set Extra HMAC authorization to Disabled.
- Set Create NAT on tunnel to Enabled.
- Set Poll Interval to 0.
- Set Redirect Internet Traffic to Disabled.
- Set Accept DNS configuration to Enabled.
- Set Encryption cipher to (Use Default).
- Set Compression to (Adaptive).
And in "Custom Configuration" I have
- Nothing
Setup to allow certain IPs to utilize VPN. Tested with MAC, PC, iPad, iPhone, Android Tablet, Android Phone and they all work.
Except with XBOX, always failed with "MTU Error".
Excerpt from Giganews Support -
"Your configurations look to be in order. You need to understand you will
not be able to connect your Xbox 360 directly to the VPN. It will have to
share the connection with a computer. We do not support Your router or
the XBox and we can not guarantee that the configurations will work."
It is driving me nuts here.
Just moved from UK to an exotic place in Europe, I have subscription with Sky and would like to use my xbox to watch sky.
Have tried all possible combinations but no success.
Willing to try other vpn providers if it is working.
Thread starter | Title | Forum | Replies | Date |
M | What is going on here!? How/Why am I Speed Testing Dual WAN (1Gbps/1Gbps @ 1:1 Load Balance) at ~2 Gbps speed | ASUS Wi-Fi | 10 |
Welcome To SNBForums
