Anyway to show clients RSSI?
scutzi128
In the webgui I see just symbols and text indicating signal strength. Is there anyway to show the actual RSSI value in the GUI? Running 384.14 on ac-3100 I searched the forums but don't see anything. Thanks!
The information is only available on the Wireless Log page.
Is there anyway to view RSSI of devices connected to an AImesh node? I believe it is only showing the main AIMesh router clients. When I go to the ip of the ai mesh node it just redirects me to the main router webpage.
separate issue but my node keeps going offline....stays up and works great for about 12 hours then shows as offline even though I can ping and ssh into it. Reboot it and its back working again. This is using a wired backhaul with a direct cable between router and node. I know this portion of the software is pretty closed but does anyone have any thoughts or similar issues? With a possible fix? Everyone I see mentioning similar issues seems to have been over a year ago when aimesh first came out. Both router are running latest firmware and are ac-3100 as mentioned above.
Edit: I downgraded to 384.13 and it seems to have fixed the stability issue with aimesh been running fine for almost 24 hours now.
