regencymanagement
Hi all,
I am trying to figure out the best and cheapest solution for a 20 unit apartment complex. We need hotspot management software and router configuration.
my thoughts.
option 1
1. outdoor access point en genius enh210
2. connected to win 7 machine running hotspot software from http://www.antamedia.com/
they say that it is only an outdoor access point but can you use it to get signal indoors? that would cut the cost of running many indoor wifi routers and all the power and cat 5 to them
option 2
1. purchase multiple cheap wifi routers- home class ones and string up about 6 of them all to cat 5 and a switch
2. switch connected to win 7 machine running hotspot software from http://www.antamedia.com/
any recommendations? or better hotspot management software? or any better ideas?
my thoughts.
option 1
option 2
