Apparent buffer overflow on FW .9313 (AC3200)
Puppa
Looks like Asus forgot to check on the size of the manufacturer name before they copy it into the Network Map. And no, I don't have a satellite dish or anything with that MAC address on my wired network, so there's likely a buffer overflow going on somewhere...
From original designer, there are two issues on this picture:
1. vender information string length : will fix
2. IEEE OUI server is broken.
Again? I think it's the second time the IEEE website gets changed in recent months, breaking this functionality. Might be time to look for using a different OUI database :(
Or forget the useless DB.
Can someone make a good case for the OUI DB? For me (small home network), it is either interesting or simply confusing. It is definitely not a requirement.
Admittedly, it is interesting though. My DSLAM is apparently some medical device... ;)
The OUI database is an easy way to determine what device belongs to a given MAC address. I've found it useful on numerous occasion. When I want to know if a given IP lease belongs to a test router or to one of my mobile devices, I check its manufacturer.
(I'm the one who originally added it to the firmware BTW).
Seems like the DB lookup should be a click-to-see type item, as I only look at it for unfamiliar devices. Either that, or they make sure not to copy an entire 200-byte string into a 16-byte field.
