I have a number of Apple clients in my network. Most are ok, but the UI consistently incorrectly identifies at least one of them.
Apple Airport Extreme: I use a static IP of 192.168.1.6 on this device.
Apple-TV: I use a Dynamic IP for this device, but manually tie it down to 192.168.1.210
However, on the list of network clients, it consistently shows 192.168.1.210 to be the Apple Airport Extreme (not the Apple-TV, as it should be) with 2 clients connected though it. This is totally incorrect. 192.168.1.6 doesn't show up at all.
I can confirm that my DHCP (managed by the AC87U) starts the DHCP address pool from 192.168.1.100.
There is only one DHCP server on my network.
If I use "who's on my network" from another utility (WiFi Scanner - MacOSX), it correctly identifies both clients at their correct IP addresses. So it really does look like a bug on the ASUS.
Anyone?
Anyone?
