Archer AX11000 not getting full speed (TP-Link)
LFC92
I currently have the Archer AX11000 with firmware version 2.1.6 Build 20230907 rel.65510(4555) and 1Gig download from my provider. I can't get the full speed of my ISP or even close to it without a switch/a 2.5gbps network card, because even with Qos off and changing the duplex speed to 2.5gbps i still only get about 500/600mbps through the router. A friend of mine lent me the switch, card and brand new ethernet cables and the highest i can get through them is 940mbps. TP-Link support said about factory resetting the router, which i did this morning and it's still the same. The speed through my ISP hub alone is over a gig, so the ISP isn't the issue. Am i missing something? Thanks.
Not very clear what the switch and the 2.5GbE card are used for. This router can do easily Gigabit, but it has single 2.5GbE WAN port. Wired devices will be limited to 940Mbps, wireless devices - depends on client capabilities and environment factors, 500-600Mbps is very good.
940 Mbps sounds about right for speed, if your ISP isn't over-provisioning. I get about same speed on my 1 Gbps plan here, using a MikroTik router. Even if WAN is 2.5 Gbps, you won't get more than a Gbps on wired LAN due to LAN ports being only 1 Gbps. If you have a very fast AX wifi, you can pull more than a Gbps assuming your ISP plan is more than 1 Gbps.
TP-Link 2.5 Gigabit PCI Express was the card and the switch was a Brostrend one from Amazon. I've seen people have this issue on the TP link forum and they managed to fix it, i tried those fixes and nothing worked for me. Prior to my ISP hub dying i did get a gig or just over through my router, since it's been replaced i can't get that speed and it's only possible through my ISP hub. I have also seen people being able to get 1gig on my ISP through a router on the forums, but maybe they have a better router etc but i don't really understand it. Thanks for the replies :).
