1. Looking for a simple and 100% reliable way to determine if an Asus router supports VLAN management and Guest Network Pro. Is that the case with any and all models that are on the v3.0.0.6.102 codebase, or are there models that lack such functionality?
Why not just look at the specs? Well, they are lacking. Case in point: the ASUS RT-BE86U page advertises Guest Network Pro, while the ASUS RT-BE92U and RT-BE58U do not. However all three advertise "LAN Link Aggregation". Which brings me to question no. 2:
2. Is "LAN Link Aggregation" a reliable indicator that an Asus router supports VLAN management and Guest Network Pro? Can there be routers that support "LAN Link Aggregation" while lacking explicit VLAN support?
Thank you!
p.s. aside:
Would have been great if they put "Pro" at the end of all models that have this, like they did for the AX models. But, hey!
Thank you!
p.s. aside:
