Hello!
My NAS needs are meager. I have a portable 4TB USB drive that stores all of my FLAC music files (which is all I care to access, no video). Previously, it was connected to a USB port on a router for a down-and-dirty NAS. I accessed this music on my Onkyo receiver, which has network capabilities. I also have an 8TB USB LaCie hard drive which is partitioned, and serves as a backup drive for my two Mac computers (clones, using Carbon Copy Cloner) and the 4TB music drive on separate partitions. (All are formatted for Mac OS Extended Journaled file system)
I've since moved, and now use the FiOS G1100 router, which doesn't allow for USB NAS sharing. I'd like to share my music once again to the Onkyo, and also make it easier to access the 8TB backup drive without having to physically move it around to back everything up.
Would it be possible to either:
A. Get a single bay NAS, fill it with an 8TB drive (maybe even pry the one in my LaCie enclosure out and use that one), wire it to a LAN port on my G1100, connect the 4TB USB drive to a port on it and have it be visible on my network as it used to be? And would all of the partitions on my 8TB drive be available as well, so I could continue to clone the Macs incrementally over the network?
B. Get a dual bay NAS, fill it with a new 4TB drive just for the music (which I'll copy over from the USB drive) in one bay, and an 8TB drive in the other bay which could serve as the backup drive as described above?
C. Another, better and/or simpler option?
I'm not looking for RAID, or even necessarily JBOD...I just want two distinct drives (one for music, one for total backup) to mount and be fully accessible over my Mac-formatted network.
Thanks in advance for your time and help.
