ARP binding on AC68U
enrysan0
is there a way to Bind an IP to a MAC address in Merlin firmware?
I think is called ARP-Binding. And NO is not DHCP reservation that is another thing!
ARP-Binding is "anti-spoofing", so that only that MAC address can get that IP. And none can use IP linked to another MAC address (changing it directly in the computer client)
As you can see this old router from asus have ARP-Binding:
attachment.php
http://wisp.pl/al/demo/RT-N10E/tcpip_lan_bind.htm
I found a way to get the same result using iptables FORWARD rules but it's a little messy to get it work with all my other iptables rules for "VPN selective routing" and Parental Control
Is possible to implement ARP-Binding natively in Asuswrt-Merlin?
I have no plan of implementing this. You will have to do it manually using user scripts.
Hi Rmerlin, sorry to revive a so old post.
First of all I'm newbie on this routers matters and also just purchased an Asus AC68 router, and one of my necessities is be able to do WOW, so would know where can find information about scripts or instructions about how set static assignment into ARP table.
Many thanks in advance.
Rgds.
