Solved [ASK] Traffic Monitor Not Working After Merlin Upgrade to 386.2_4 - Asus RT-AX56U
adzie
Hello Expert,
as per subject, suddenly my Traffic Monitor is not working after I perform SW Upgrade from 386.1_2 to 386.2_4.
Daily traffic and last 24 hours traffic are not able to shown
however for statistic per device or apps is working fine..
any suggestion to fix this problem?
thank you in advance for all the answer and advice.
Do you see data when you set the monitor to "Real-time"?
What do you have set for Tools > Other Settings > Traffic Monitoring > Traffic history location? If it's set to RAM the data will be lost when the router is rebooted.
thanks Colin for the reply. it turns out my flash drive was corrupted and I was saving the data for the traffic into that flash drive..
will close the thread.
