Astril VPN still connected even though its disabled
Deanoz_uk
I have RT-N66U with Asuswrt 3.0.0.4.376.49_2 installed and I'm currently doing a 7 day trial of the Astril VPN Service.
I'm using the Astril VPN applet version 2.93 installed from there member area.
I have it configured to direct traffic from 2 devices on my network over VPN which works flawlessly.
However twice since installing this 4 days ago I have logged onto my router and noted the WAN IP address to have changed to a US based Astril address and if I check the IP address of a client the external address is shown as the same address so all traffic is being routed out via the VPN.
I can then go into the Astril applet disconnect from astral but the VPN wan IP won't update until the router is rebooted.
I can then enable the service and it works as it should for a while.
Anyone experienced similar behaviour or have any ideas how I can investigate whats causing this?
Many Thanks
Deano
