Astrill VPN applet kept disappearing after reboot of the asus router
chercm
i have tried all method to set enable JFFS partition to no and Format JFFS partition at next boot to yes and reboot the router and after that to set enable the partition and reboot
after doing all these it is still not working , any one can help ? :mad::mad:
What model router and code?
Make that just code....see it's an AC68U in your previous post.
The script should be in /jffs/scripts, not in /jffs.
ASUSWRT-Merlin RT-AC68U_3.0.0.4 Sat Sep 20 18:50:48 UTC 2014
admin@RT-AC68U-FD10:/tmp/home/root# /jffs/scripts/init-start
admin@RT-AC68U-FD10:/tmp/home/root# Installing Astrill VPN binary... /bin/sh: eval: line 1: can't create /tmp/astrill/openvpn: Text file busy
FAILED
WARNING: Default OpenVPN binary will be used. Stealth Mode is not available.
Yes sorry typing too fast.
FAILED
I can't tell you what that means, but that's your problem. That's how the applet loads itself at boot and it is erroring out.
i think you have mistaken that i have yet to disable it as i have installed it manually
admin@RT-AC68U-FD10:/tmp/home/root# Installing Astrill VPN binary... done.
Have you gone to Astrill's web site and looked at the instructions for installing the App? On the newer versions of Merlin's firmware a different procedure is required than in older versions.
Hey, maybe you can check this answer, I found there seems like a same issue:
- disappearing file: openvpn
- disappearing Astrill applet interface.
