w00tington
Hello all,
I was wondering if someone could give me some insight on an issue I'm having.
I can run SABnzbd and sickbeard concurrently, but then I run into issues when I try to run couchpotato / headphones as well, as it runs into memory issues:
I'm guessing there will be no way of running SABnzbd + sickbeard + couchpotato + headphones concurrently on the router due to the memory available? Is there a way or reducing the amount of memory used by each program?
If not running concurrently, how does everyone automate the process of starting / stopping the daemons you need?
Thanks in advance.
File "/opt/lib/python2.6/logging/__init__.py", line 1056, in info
self._log(INFO, msg, args, **kwargs)
File "/opt/lib/python2.6/logging/__init__.py", line 1173, in _log
self.handle(record)
File "/opt/lib/python2.6/logging/__init__.py", line 1183, in handle
self.callHandlers(record)
MemoryError
total used free shared buffers
Mem: 255652 209852 45800 0 2260
-/+ buffers: 207592 48060
Swap: 0 0 0
Thanks in advance.
