This took a whole day to fix. So I'm posting it here since this forum pointed me to the right direction
So the issues is that where I live when you get a home fiber or cable connection from any provider they give you a device as a modem/router combination. They will not give you just a modem device. So I wanted to extend the wireless signal.
So since I had the AC-88U lying around and not being used (from an older inbstallation) I used it as a repeater.
Well using the latest firmware version 3.0.0.4.384.81116 I tried setting it up. But it could never work. I was always getting the error that the password that connects to the Parent AP is wrong.
I tried everything. Well to cut the long story short. I downgraded the the firmware version 3.0.0.4.384.32799 and it worked instantly. I am not sure if this is will be a perfect solution but I will be monitoring it and add to this thread.
Thanks to this forum since it help me understand what was happening, so I hope this post will sort of Pay it forward.
