This just happened:
Swapped some power outlets so router rebooted (Not too fast)
Now the router is just showing led flash on ETH2/3 or 4. Eth1 doesn't seem to work, WAN and USB2.0 (No cable there)
Ive tried setting in recovery mode (Power on with reset button pressed 15-20 seconds) and NVRAM reset with WPS button power on 15-20 seconds pressed. But the power lamp is never blinking. Maybe it's supposed to not blink on this mode? Not sure. I've tried connecting a PC directly in eth 2-3 or 4 and static ip 192.168.1.2 (GW .1) no luck, can't even ping (if its supposed to respond to ping).
It's strange, it's doesnt seem to boot, it's just power on -> lights on eth x and usb2.0. Nothing more happens.
The router was flashed with AsusWRT Merlin, some firmware from mid-summer ish version don't remember.
Is it possible to solve this somehow? As long as I can't see power led flashing im not sure if I have activated recovery mode, or if it's really working at all.
Here is a video of boot:
https://www.dropbox.com/s/0b34fj61k1diw9t/2015-09-17 19.05.41.mp4?dl=0
