The bugs I found in the new software, (384.12)
1. Manual restart does not function. When you click Restart, it counts like a restart, but the router does not start again.
2. Changes to port forwarding do not take effect until you switch the device off and on. Of course, I have to turn the device on and off because of the first error.
3. I wanted to do a reboot from the command line SSH connection settings by making the open LAN, WAN LAN, although the connection can not be established. Trying with Putty gives connection refused error. When I try to make a telnet connection, it gives the same error. No more Telnet settings in the administration - system settings, by the way.
Edit:
The SSH connection worked after turning the device off and on.
Edit:
