Asus AC3200 380.61 Port Forwarding
ssj4gokou
I am having an issues with port forwarding on Merlins 380.61 firmware. I go the settings that type in the name of the app, the port number, change to both and then hit add. I finish up and click on Apply, the pages refreshes, but it is never saved.
Am i doing something wrong here or is anyone else experiencing this issue too?
What browser are you using? Try a different one (IE, FF, Edge) or try clearing the browsers cache and/or rebooting the computer you are using to control the router with.
I have seen that to, I just refresh side and after that hit apply.
I have attempted to do that on Windows PC / Macbook and even my iPhone. I have tried Edge, Firefox, internet explorer, opera and safari with no luck. Been tempted to upgrade to the latest merlin firmware, but the last time I upgrade my network speeds suffered tremendously and this issue was still present.
Sounds like you need to do a reset to factory defaults?
In that case, I would recommend you unplug all USB devices and reboot the router. Wait 5 minutes and then flash the latest RMerlin firmware.
Now, follow the steps below to get your router to a good/known state before you try troubleshooting further.
http://www.snbforums.com/threads/no...l-and-manual-configuration.27115/#post-205573
http://www.snbforums.com/threads/rt-ac66u-slow-wan-to-lan.12973/page-3#post-269410
http://www.snbforums.com/threads/faq-nvram-and-factory-default-reset.22822/
Before you do the above, you may want to use the utility below to save a record of all your settings in human readable form (and copy/paste able form too).
http://www.snbforums.com/threads/user-nvram-save-restore-utility-r24.19521/
Check your nvram utilitzation on the Tools > Sysinfo page. You need to have about 5K free space for everything to work correctly.
Oh! That may be! i was reading it as i am using 65550 out of 65536.
Is there a way to clear it out?
Yes. That is 'more' than you actually 'have'. :)
Haha! I re-read that! My bad!
So i went ahead and executed some commands in terminal was able to free some space back up.
nvram set nmp_client_list=
nvram commit
However, i do have a quick question? How do i go ahead and configure a script to configure this to run at a certain time everyday?
