Hello All, (This is a duplicate post. I posted in the wrong forum originally)
I'm hoping someone can help me troubleshoot my issue. I have an ASUS AC5300 and I am trying to connect my Honeywell Smart Thermostat to my wifi network using their Android Phone App. The phone app tries to connect the thermostat to the home wifi network. It only works on a 2.4 Ghz band. The connection fails every time with no real error message displayed. I know it is a setting in my router because when I setup a mobile hotspot using a different phone, then connect the phone and thermostat to the mobile hotspot it works.
Here are the specs that the honeywell router requires:
· Ensure you are connecting to a 2.4 GHz network. Honeywell Wi-Fi thermostats are not compatible with 5 GHz network.
· Ensure the router is set for DHCP.
· Ensure the following ports are open: 114. (Lyric T Series also require ports 5671, 5672 to be open)
· Ensure the network is a standard home network and does not require logging in from a web page such as a guest network.
· Ensure the Wi-Fi network is using one of the following security protocols:
· OPEN
· WEP PSK
· WPA TKIP PSK
· WPA2 AES PSK
· WPA2 MIXED PSK
· Honeywell Wi-Fi thermostats are NOT compatible with the following security protocols:
· WPA AES PSK
· WPA2 TKIP PSK
I am fairly sure I meet all of these requirements but I don't know if a firewall in the router is blocking those ports. Any help will be greatly appreciated!
Thanks,
Terry
· OPEN
· WEP PSK
· WPA TKIP PSK
· WPA2 AES PSK
· WPA2 MIXED PSK
· WPA AES PSK
· WPA2 TKIP PSK
Thanks,
Terry
