I bought a AC5300 router on criaglist and have the following issue and need help. Region is US.
1) Speeds on first 5ghz band is very slow - 20-90mbos. My old AC1900 gives me 120mbps (max of my internet provider)
2) The First 5ghz Band is missing the higher control channels 149-165. I only see the lower channels 36-48. On my old ac1900 I see all the channels.
3) Second 5ghz band is totally non functional . I can set ssid, etc, guest ssid for it, but it does not appear to be broadcasting. I cant see any control channels , the drop done shows auto and channel 0
I have updated to the latest firmware, Merlin, old firmware, did the proper flash and reset procedure.
Help needed, TIA.
Help needed, TIA.
