Eric.G
Hi;
I've recently purchased a AC5300 and installed the Merlin 384.5 firmware. I had set this up with one main SSID with Smart Connect for the 2.4GHz and both the 5GHz radios, and two guest SSID
(one for the 2.4GHz band and one for the 5GHz radio 1)
Funny thing is that after a reboot it seems to run for a small amount of time (always less than 1 hour), and then the router becomes unresponsive though packets seem to still be getting through (The admin panel and the authentication of new devices stops working).
This continues unless I restart the device and disable the second 5GHz radio in the Professional tab of the admin pages. From then it behaves very well. But I'd really like to be able to take advantage of both radios.
The device is behind a separate firewall and is currently functioning as a simple AP. I'm somewhat at a loss as to how to diagnose this as I can't communicate with it when it's gone into the failed state. Any suggestions as to how I may be able to diagnose this problem?
I've tried going back to 384.4, but this exhibits the same issues.
-Eric.
-Eric.
