Hi there, I have a Pi-Hole (2x) local ones running a virtual high availability IP - 192.168.1.20
Is there a way to set up IPtable rules to force all port 53 and 853 traffic through this IP? I see many different results on reddit and my knowlege on iptables is pretty limited so just wanting to seek some clarification.
FWIW I also have spun up a new pihole instance in an always free oracle cloud tier following chadgeary github guide. Not sure if we are able to use multiple IP addresses with iptable rules and if that is a limitation I guess just having the 2x piholes on my local network will be sufficient. I was using dnsfilter option for a while but I've heard it doesn't redirect port 853 traffic so happy to disable that feature and just run iptabling. Please let me know your thoughts and I'd like to see if I can get this up and running Thanks!
