ravennevar
Hello. I have an Asus AC68U with stock firmware and I am trying to set up OpenVPN. I have followed tutorials carefully (I have have also done this myself many times with other routers with both stock and alternative firmware). I am getting "authentication failed" even though the username and password are correct. Please see attached log from the router. I am out of ideas about what else to do. Any suggestions are greatly appreciated.
Aug 29 23:28:00 vpnserver1[7216]: Server_IP:61734 TLS: Initial packet from [AF_INET]Server_IP:61734 (via [AF_INET]Client_IP%vlan2), sid=8df2bbd8 705f90d1
Aug 29 23:28:01 vpnserver1[7216]: Server_IP:61734 VERIFY OK: depth=1, C=TW, ST=TW, L=Taipei, O=ASUS, CN=RT-AC68U, emailAddress=me@myhost.mydomain
Aug 29 23:28:01 vpnserver1[7216]: Server_IP:61734 VERIFY OK: depth=0, C=TW, ST=TW, L=Taipei, O=ASUS, CN=client, emailAddress=me@myhost.mydomain
Aug 29 23:28:01 vpnserver1[7216]: Server_IP:61734 PLUGIN_CALL: POST /usr/lib/openvpn-plugin-auth-pam.so/PLUGIN_AUTH_USER_PASS_VERIFY status=1
Aug 29 23:28:01 vpnserver1[7216]: Server_IP:61734 PLUGIN_CALL: plugin function PLUGIN_AUTH_USER_PASS_VERIFY failed with status 1: /usr/lib/openvpn-plugin-auth-pam.so
Aug 29 23:28:01 vpnserver1[7216]: Server_IP:61734 TLS Auth Error: Auth Username/Password verification failed for peer
Aug 29 23:28:01 vpnserver1[7216]: Server_IP:61734 Control Channel: TLSv1, cipher TLSv1/SSLv3 EDH-RSA-DES-CBC3-SHA, 1024 bit RSA
Aug 29 23:28:01 vpnserver1[7216]: Server_IP:61734 [client] Peer Connection Initiated with [AF_INET]Server_IP:61734 (via [AF_INET]Client_IP%vlan2)
Aug 29 23:28:01 vpnserver1[7216]: Server_IP:61734 PUSH: Received control message: 'PUSH_REQUEST'
Aug 29 23:28:01 vpnserver1[7216]: Server_IP:61734 Delayed exit in 5 seconds
Aug 29 23:28:01 vpnserver1[7216]: Server_IP:61734 SENT CONTROL [client]: 'AUTH_FAILED' (status=1)
Aug 29 23:28:06 vpnserver1[7216]: Server_IP:61734 SIGTERM[soft,delayed-exit] received, client-instance exiting
Aug 29 23:28:27 vpnserver1[7216]: event_wait : Interrupted system call (code=4)
Aug 29 23:28:27 vpnserver1[7216]: /sbin/route del -net 10.8.0.0 netmask 255.255.255.0
Aug 29 23:28:27 vpnserver1[7216]: Closing TUN/TAP interface
Aug 29 23:28:27 vpnserver1[7216]: /sbin/ifconfig tun21 0.0.0.0
Aug 29 23:28:27 vpnserver1[7216]: PLUGIN_CLOSE: /usr/lib/openvpn-plugin-auth-pam.so
Aug 29 23:28:27 vpnserver1[7216]: SIGTERM[hard,] received, process exiting
