Mardimus
Took on a new project to improve wireless networking at my cabin in the mountains and need a bit of help.
Setup:
AC68U running Merlin 384.14
or
AC68U running DDWRT v3.0 R41813 std
(I have two routers so either one can be used. Testing two different builds to get this to work)
iPhone is a 6S Plus on Visible (Verizon prepay)
Phone is jailbroken via CheckRain and using the tetherme app
So the goal is to tether the phone to the router via usb and use the router to connect multiple devices.
I got this working on a TP link router using repeater mode. So the phone sits in the window and the hotspot is on and the router then takes the signal and distributes it to the remaining wireless devices. The issue is that the signal drops in and out and then you have to turn the hot spot off and back on to reset the connection.
What I would like to do is have it tethered via usb to keep the connection intact or at least try to test the difference, tether vs hotspot.
On DDRWT I go into settings and select iPhone tether, Phone is plugged into usb3.0 port, and when plugged in the phone asks to trust the (device), I click trust and it shows on the phone its tethered. The issue is the the router does not have a network connection coming in.
When I connect/tether the phone to my PC I get a ip address and can run speed test with no issue.
On Merlin I only get the option for Android or USB Modem (i think) and run into the same issue except it doesn't even show the usb port has anything connected to it.
Looking for some insight, searched for the last three days and have tried a lot of little tricks or techniques but no solution. Let me know if you have any insight as I would like to get this worked out before I go back to my old method.
Setup:
or
