you mean 1Gb?. Add your download and upload together and it gives you your forwarding speed. If you are happy having only 1Gb/s of forwarding than your current router with hardware NAT is fine otherwise you will need a totally different router. Upgrading gives you faster CPU but if your NAT speed is sufficient i dont see why you need to upgrade other than for the hardware which you may not use.
I recently just upgraded providers from 60meg to 1GB. There is a 200meg difference from the modem ports and from my AC68U ports. Is there anyway to optimize this or should I look for a new router? Thanks for all your help guys I am currently running Merlin 380.59_0
Just to illustrate why is this ASUS BRT-AC828M2 is fully dual WAN 1Gbps capable up to 2Gbps and hardware NAT router.
One picture is worth more than a thousand words
The RT-AC1900P (BB exclusive right now), RT-AC3100, RT-AC88U and the RT-AC5300 all come with 1.4GHz dual core processors (about 75% faster than the original RT-AC68U came with). But they all have 1Gbps (max) routing speeds.
The BRT-AC828/M2 is what you want (particularly if you have symmetric 1Gbps u/d speeds).
http://www.snbforums.com/threads/ne...-dual-wan-vpn-router.32839/page-2#post-265829
I don't think the BRT-AC828/M2 is available (anywhere) though. But it is the only one worth upgrading to with your ISP speeds.
Any currently available router is not worth upgrading to (even if it tests a little higher in WAN to LAN and LAN to WAN) right now. Just pray the BRT-AC828/M2 doesn't cost as much as a small home.
Thanks so much for the information, I am interested to see if my new connection requires reboots. The AC1900 at bestbuy I thought had a shorter range then the original. I think you guys so much now I have to configure the uverse router son couldn't do chat on xbox after the switch.
Note; 'AC1900' is a class of WiFi. 'RT-AC1900P' is the model I'm referring to.
Lol I know I just have experienced reboots with my ac1900 for a long time (well having to reboot) because the wifi would lock up. I haven't found a firmware to alleviate this issue and if another model or newer makes that possibly I am all for it. As it will make my home network less maintenance intensive as well.
Which model are you talking about? Linksys?
We're talking about the Asus RT-AC1900P here.
Welcome To SNBForums
