Asus AC68U Port Forward Issue
el kido
Having trouble getting the port forward setup on this router and also have an Asus AC66U at another location with same issue.
Installed Merlins FW Still no luck as far as getting ports visible. As of right now I do not need a specific port, just need Canyouseeme.org to see me.
My Modem is the Motorola SB6141--->Asus AC68U---PC. Here are just some samples of what i have. Any suggestions are appreciated.
A port forward implies that you have a running service answering to that port on the target IP. If you forward port 110 but you don't run a POP3 server, then any port forward checker will fail since nobody will be there to answer connection attempts.
Hey RMerlin. Ended up getting it going once I put the device in there. who woulda known ;)
Now going to set it up with my AC66U but will need to flash your firmware on that one too first. Essentially trying to setup a Q-See DVR (QT5516) to get remote access. Will post back if any issues or closing comments for future searches...
