punchsuckr
Hi!,
I recently got an Ac86u after years with the n66u on john's fork. Updated to the merkin firmware 384.18 about 10 days ago.
I have a vpn server setup which is rock solid with very little overhead and excellent throughput. It was working just fine for about 6 days when today all 5ghz clients disconnected when I just woke my laptop from standby.
All lights were on, and vpn was working just fine but the wireless symbol showed up as half and displayed channel 0 for 5ghz.
I have seen one exact same issue reported around 2 years ago but was apparently due to the user migrating settings or something which I haven't done. The router was setup as new and I had updated to merlin fw from stock upon first boot before I configured it.
Some settings I have changed from default:
5ghz is set to use channel 36 with other settings (some of my clients don't see the channels in the high 100+mhz range) on auto.
Smart connect is off. I only use the 5ghz band with no clients on 2.4 (it is a different ssid).
WPS is disabled for security.
Adaptive qos is on, aiprotection is on.
I saw the following messages in the log when this occurred. This goes on for many more lines.
Censored MAC of my laptop because I do not know.
Any help is deeply appreciated. Hoping this is not a hardware issue.
Thank you.
21:06:45 wlceventd: WLCEVENTD wlceventd_proc_event(500): eth6: Auth 58:00:**:**:5A:BD, status: Successful (0)
Aug 9 21:06:45 wlceventd: WLCEVENTD wlceventd_proc_event(529): eth6: Assoc 58:00:**:**:5A:BD, status: Successful (0)
Aug 9 21:06:47 kernel: DUMP CONSOLE: xstrt 0
Aug 9 21:06:47 kernel: DUMP CONSOLE: 574816.584 ampdu_dbg: cwcur0-3 f f 7 3 bslots cur/0-3 15 0 0 0 0 ifs_boff 0
Aug 9 21:06:47 kernel: DUMP CONSOLE: 574816.584 ampdu_dbg: again1 ifsstat 0xaf nav_stat 0x0
Aug 9 21:06:47 kernel: DUMP CONSOLE: 574816.584 ampdu_dbg: again2 ifsstat 0xaf nav_stat 0x0
Aug 9 21:06:47 kernel: DUMP CONSOLE: 575362.584 ampdu_dbg: wl1.0 50:3e:aa:49:75:69 scb:00333a58 tid:4
Aug 9 21:06:47 kernel: DUMP CONSOLE: 575362.584 ampdu_dbg: wl1.0 dead_cnt 2 tx_in_transit 1 psm_mux 0xfff0 aqmqmap 0x0x404 aqmfifo_status 0x0x4000 fifordy 0x0 cpbusy 0x0
Aug 9 21:06:47 kernel: DUMP CONSOLE: 575362.584 ampdu_dbg: ifsstat 0xaf nav_stat 0x0 txop 108007
Aug 9 21:06:47 kernel: DUMP CONSOLE: 575362.584 ampdu_dbg: pktpend: 0 0 0 0 0 ap 1
Aug 9 21:06:47 kernel: DUMP CONSOLE: 575362.584 ampdu_dbg: txall 52 txbcn 0 txrts 0 rxcts 0 rsptmout 0 rxstrt 0
Aug 9 21:06:47 kernel: DUMP CONSOLE: 575362.584 ampdu_dbg: cwcur0-3 f f 7 3 bslots cur/0-3 2 0 0 0 0 ifs_boff 0
Aug 9 21:06:47 kernel: DUMP CONSOLE: 575362.584 ampdu_dbg: again1 ifsstat 0xaf nav_stat 0x0
Aug 9 21:06:47 kernel: DUMP CONSOLE: 575362.584 ampdu_dbg: again2 ifsstat 0xaf nav_stat 0x0
Aug 9 21:06:47 kernel: DUMP CONSOLE: 575362.584 wl1: wlc_ampdu_watchdog: cleaning up ini tid 4 due to no progress for 2 secs tx_in_transit 1
Aug 9 21:06:47 kernel: DUMP CONSOLE: 575362.584 wl1: wlc_ampdu_tx_send_delba: tid 4 initiator 1 reason 39
Aug 9 21:06:47 kernel: DUMP CONSOLE: 575384.584 wl1.0: wlc_send_bar: seq 0x996 tid 4
Aug 9 21:06:47 kernel: DUMP CONSOLE: 575805.666 flow_create : bitmap_size=512 maxitems=2048
Aug 9 21:06:47 kernel: DUMP CONSOLE: 575805.669 wl1.0: wlc_send_bar: seq 0x1 tid 0
Aug 9 21:06:47 kernel: DUMP CONSOLE: 575805.674 wl1: wlc_rrm_recv_nrreq: Unsupported
Aug 9 21:06:47 kernel: DUMP CONSOLE: 575805.953 flow_create : bitmap_size=512 maxitems=512
Aug 9 21:06:47 kernel: DUMP CONSOLE: 575805.954 wl1.0: wlc_send_bar: seq 0x1 tid 6
Aug 9 21:06:47 kernel: DUMP CONSOLE: 575806.943 wl1: wlc_ampdu_tx_recv_delba: AMPDU OFF: tid 0 initiator 0 reason 1
Aug 9 21:06:47 kernel: DUMP CONSOLE: 575807.050 wl1.0: wlc_send_bar: seq 0xa tid 0
Aug 9 21:06:47 kernel: DUMP CONSOLE: 575807.174 wl1.0: wlc_send_bar: seq 0x1 tid 3
Aug 9 21:06:47 kernel: DUMP CONSOLE: 576120.612 flow_create : bitmap_size=512 maxitems=1024
Aug 9 21:06:47 kernel: DUMP CONSOLE: 576120.613 wl1.0: wlc_send_bar: seq 0x3 tid 4
Aug 9 21:06:47 kernel: DUMP CONSOLE: 576639.285 wl1.0: wlc_send_bar: seq 0xd09 tid 4
Aug 9 21:06:47 kernel: DUMP CONSOLE: 577125.584 ampdu_dbg: wl1.0 50:3e:aa:49:75:69 scb:00333a58 tid:2
Aug 9 21:06:47 kernel: DUMP CONSOLE: 577125.584 ampdu_dbg: wl1.0 dead_cnt 2 tx_in_transit 1 psm_mux 0xfff0 aqmqmap 0x0xb01 aqmfifo_status 0x0x4000 fifordy 0x0 cpbusy 0x0
Aug 9 21:06:47 kernel: DUMP CONSOLE: 577125.584 ampdu_dbg: ifsstat 0xaf nav_stat 0x0 txop 105203
Aug 9 21:06:47 kernel: DUMP CONSOLE: 577125.584 ampdu_dbg: pktpend: 0 0 0 0 0 ap 1
Aug 9 21:06:47 kernel: DUMP CONSOLE: 577125.584 ampdu_dbg: txall 114 txbcn 0 txrts 0 rxcts 0 rsptmout 0 rxstrt 0
Aug 9 21:06:47 kernel: DUMP CONSOLE: 577125.584 ampdu_dbg: cwcur0-3 f f 7 3 bslots cur/0-3 0 0 0 0 0 ifs_boff 0
Aug 9 21:06:47 kernel: DUMP CONSOLE: 577125.584 ampdu_dbg: again1 ifsstat 0xaf nav_stat 0x0
Aug 9 21:06:47 kernel: DUMP CONSOLE: 577125.584 ampdu_dbg: again2 ifsstat 0xaf nav_stat 0x0
Aug 9 21:06:47 kernel: DUMP CONSOLE: 577125.584 wl1: wlc_ampdu_watchdog: cleaning up ini tid 2 due to no progress for 2 secs tx_in_transit 1
Aug 9 21:06:47 kernel: DUMP CONSOLE: 577125.584 wl1: wlc_ampdu_tx_send_delba: tid 2 initiator 1 reason 39
Aug 9 21:06:47 kernel: DUMP CONSOLE: 577127.803 wl1.0: wlc_send_bar: seq 0x1b5 tid 2
Aug 9 21:06:47 kernel: DUMP CONSOLE: 577538.311 wl1.0: wlc_send_bar: seq 0x4 tid 5
Aug 9 21:06:47 kernel: DUMP CONSOLE: 578239.787 flow_create : bitmap_size=512 maxitems=1024
Aug 9 21:06:47 kernel: DUMP CONSOLE: 578239.834 wl1.0: wlc_send_bar: seq 0x1 tid 2
Aug 9 21:06:47 kernel: DUMP CONSOLE: 578443.440 wl1: Proxy STA 58:00:**:**:5a:bd link is already gone !!??
Aug 9 21:06:47 kernel: DUMP CONSOLE: 578443.440 wl1: STA 58:00:**:**:5a:bd removed from MU client set.
Aug 9 21:06:47 kernel: DUMP CONSOLE: 578443.500 wl1: wlc_recvfilter: scb is null, dont resend deauth
Aug 9 21:06:47 kernel: DUMP CONSOLE: 578443.584 wl1: STA 1c:12:b0:77:88:8c removed from MU client set.
Aug 9 21:06:47 kernel: DUMP CONSOLE: 578443.585 wlc_ucode_download: wl1: Loading non-MU ucode
Thank you.
