Hello every one
My ASUS router suddenly stopped working, i did not changed any thing.
When i turn it on, only one LED is lighten and it is USB 2.0. The Power LED is not turned on ( very very dim) , i have no USB on the router.
I tried various different outlets as well as a different adapter, i also tried an external power supply that gives the same voltage and amps, and still get the same result.
It is not possible to reset the router neither through the reset button nor the WPS button ( not possible to get any LED to blink). so even the rescue utility software cannot recognise the router.
the computer does not recognise the router any more, even if the ethernet cable is plugged in, it is shown as being unplugged.
I tried to connect it with a serial port, But getting no boot sequence
any suggestion or possibility for repair. Thank you
