gfondeur
I found it interesting ASUS didn't mentioned on AX86U pageAX86U antennas are detachable. But AX82U ones are not.
LOL? What? You are beyond wrongwhat?
the antennas on the AX86U are not detachable, for real
my AC86U more and more are looking its going to wait a litter longer for a replacement
Just got mine today too... but after server tests ive noticed my latency is higher directly wired and wireless. Ive tried QoS on and off but no luck
Hmm. Wonder if that'll get ironed out eventually?
That's on the website. 31/07Hope So! There was a firmware update today that isn't showing on the actual asus website but is coming through the router? I upgraded but there was no notes. Version 3.0.0.4.384_9283-g5afb40c ??
You obviously didn't read my following postsLOL? What? You are beyond wrong
The weird thing was tho i was already on the latest version? Im not sure whats going onThat's on the website. 31/07
ASUS RT-AX86U Firmware version 3.0.0.4.384.9283
- Fixed UI bugs that happen only in IE11.
- Fixed QIS auto-detection issue.
- Improved UI compatibility issues on different resolutions.
But yes, 82u is 4x4:4. The rest are 2x4:4 according to thiggins.
Regardless. $250~ is a little too much. Rather spend a little more on the 86U (assuming $300 now) at that point for actual hardware upgrades (much better cpu/ram) unless ASUS prices it very close to the AX88U which would be very weird for the sake of an upgraded 2.5g port (with less switch capacity). also downgraded 3x3 2.4g.. yeah idk..
@vessosa, I would not buy the inferior RT-AX82U with its weaker SoC (3x 1.5GHz CPU cores). The RT-AX86U has 4x 1.8GHz CPU cores, 1GB RAM, and that RJ45 for 2.5G BaseT connection too. In addition to the AES-NI hardware accelerator for VPN connections that will make it up to five times faster than the 'AX82U with the right ISP(s).
Interesting comment, but could you explain to a noob to VPN's what you mean about the "AES-NI hardware accelerator for VPN connections"? I have just started using an RT-AX86U and with a little help from my son, managed to not only set up a VPN to my router but also reconfigure network shares mapping on my NAS so they work whether accessed via the internal network or externally via the VPN. The part that had got me foxed was that I needed to specify the fixed IP address of the Synology Diskstation in the mapping of the network shares and any associated shortcuts, rather then using the description "Diskstation".@vessosa, I would not buy the inferior RT-AX82U with its weaker SoC (3x 1.5GHz CPU cores). The RT-AX86U has 4x 1.8GHz CPU cores, 1GB RAM, and that RJ45 for 2.5G BaseT connection too. In addition to the AES-NI hardware accelerator for VPN connections that will make it up to five times faster than the 'AX82U with the right ISP(s).
@TheLyppardMan, an AES-NI hardware chip is an additional hardware that offloads from the main CPU's what OpenVPN or other VPN connection require to keep things encrypted within the VPN tunnel.
Numbers don't mean much. Better to focus on router/AP placement and clients...Is the AX86U supposed to be better than the AX88U? This is confusing to me I thought higher number means better?
Welcome To SNBForums
