Terrance Curry
I have the RT-AX88U Asus router as my main router and use its
AiMesh feature with 4 other Asus (legacy) router that support
AiMesh as nodes (namely RT-AC88U, RT-AC86U, RT-AC66U B1 & RT-AC68R).
I was using Asus stock firmware in all of them and decided to use
Merlin firmware in all them again for some reason.
I was wondering if there an app for the android phone or devices
like Asus Router or Asus Router Discovery that work when the
Merlin firmware is applied? I ran the apps on my android devices
but it could not find any Asus routers since I switched the firmware.
So are the apps for Asus compatible with running Merlin firmware
within the Asus routers? Am I doing something wrong or is
there a compatible app through Merlin and Asus before I may
consider switching back to Asus stock firmwares.
Thank you.
Thank you.
