Ahmed Al Fahim
i purchased a few AX6600 mesh WiFi’s and had a couple of questions cause I’m setting it up in a large space with thick Walls.
1) how many nodes can I connect to one WiFi network or router. I have already connected 3 and need more to fill the full space.
2) I have multiple access point Ethernet wires connected to the Main router that I have attached nodes too which works fine. However I have run out of Ethernet connections and now want to connect extra nodes via Wireless connectivity. Issue is the main router is too far to connect these extra nodes wirelessly. What I have read is you can only connect a node wirelessly to the main router. Question is, can I connect nodes wirelessly to the access point nodes which are connected to the main router via Ethernet vs directly to the main? If so how can I set that up?
thanks
thanks
