ASUS AX11000 - Wifi Site Survey
dkasseb
Anyone know why the Wifi Site Survey only lists your own APs? I am not sure why it wouldn't pick up the neighbors. Is it defective? Or do I have to configure something. Thanks!
Make sure you enable data collection on the settings page.
I have this working on 2.4 but for 5ghz I get this message below
Unable to perform scan.Showing cached results
No idea. Wifi Insight is a closed source application from Broadcom.
This only recently started happening for me too.... it happens on the 5 AND 6 gHz channels, but the 2.4 continues to operate as it always has.
Just updated to 386.5_2 and I'm getting this on RT-AX86U as well. I suspect it's been like this for the last few versions.
Interestingly, I just revisited the WiFi survey page and although the error is still there, I AM seeing results:
Interestingly, I just revisited the WiFi survey page and although the error is still there, I AM seeing results: View attachment 40376
Ah, I think I've narrowed this down a bit further. The error has gone and the only channel I can see that is missing is my own, running at 160MHz. All the visible APs are running with either 20, 40 or 80 MHz. The 160MHz is missing.
I actually just checked this since you quoted my post and I got the alert and its working fine for me now on 5Ghz
I still seem to get nothing at all with 5ghz network. 2.4 is working ok, but even with data collection started and running for the last 48 hours, I can't see any other 5ghz radios and I get the 'Unable to perform scan.Showing cached results' error
