Shiang
Hi all, I am new to the forums. Need some advice on my setup.
Router: Asus AX11000
Mesh: Asus Rt-AC88U
My Asus AX11000 router with the latest firmware .7979. I have a unit of Asus RT-AC88U given by friend as a gift two years back which I kept in store. Recently I though of having that to be my Air Mesh Node. I was successfully connected it to the AX11000 as a node. but keep having some strange behavior such as my, I only having only 230mbps for my 5GHz 2 at the max. The AC88U just right infront of me and I am getting this speed. The 5GHz 1 was getting constant 975mbps though. Lately I am getting some strang log from Asus AX11000 shown below. Hope some guru here can help me. Thank you.
Feb 2 00:20:58 wlceventd: wlceventd_proc_event(427): eth8: Auth 8C:B8:4A:4C:FA:2B, status: 0, reason: d11 RC reserved (0)
Feb 2 00:20:58 wlceventd: wlceventd_proc_event(455): eth8: Assoc 8C:B8:4A:4C:FA:2B, status: 0, reason: d11 RC reserved (0)
Feb 2 00:21:14 wlceventd: wlceventd_proc_event(409): eth8: Disassoc 8C:B8:4A:4C:FA:2B, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8)
Feb 2 02:26:58 acsd: eth8: staying in current channel as txop is recovered with in time limit
Feb 2 02:59:32 kernel: eth4 (Ext switch port: 3) (Logical Port: 11) (phyId: b) Link DOWN.
Feb 2 03:23:13 acsd: eth8: staying in current channel as txop is recovered with in time limit
Feb 2 05:02:22 WATCHDOG: [FAUPGRADE][auto_firmware_check6148)]period_retry = 0
Feb 2 05:02:23 WATCHDOG: [FAUPGRADE][auto_firmware_check6177)]retrieve firmware information
Feb 2 05:02:23 WATCHDOG: [FAUPGRADE][auto_firmware_check6193)]no need to upgrade firmware
Feb 2 05:02:52 WATCHDOG: [FAUPGRADE][auto_firmware_check6148)]period_retry = 1
Feb 2 05:02:53 WATCHDOG: [FAUPGRADE][auto_firmware_check6177)]retrieve firmware information
Feb 2 05:02:53 WATCHDOG: [FAUPGRADE][auto_firmware_check6193)]no need to upgrade firmware
Feb 2 05:03:22 WATCHDOG: [FAUPGRADE][auto_firmware_check6148)]period_retry = 2
Feb 2 05:03:23 WATCHDOG: [FAUPGRADE][auto_firmware_check6177)]retrieve firmware information
Feb 2 05:03:23 WATCHDOG: [FAUPGRADE][auto_firmware_check6193)]no need to upgrade firmware
Feb 2 05:23:30 acsd: eth8: staying in current channel as txop is recovered with in time limit
Feb 2 05:38:33 acsd: eth8: staying in current channel as txop is recovered with in time limit
Feb 2 07:16:37 ntp: start NTP update
Feb 2 10:49:57 acsd: eth8: staying in current channel as txop is recovered with in time limit
Feb 2 15:26:52 wlceventd: wlceventd_proc_event(427): eth8: Auth 8C:B8:4A:4C:FA:2B, status: 0, reason: d11 RC reserved (0)
Feb 2 15:26:52 wlceventd: wlceventd_proc_event(455): eth8: Assoc 8C:B8:4A:4C:FA:2B, status: 0, reason: d11 RC reserved (0)
Feb 2 15:27:18 wlceventd: wlceventd_proc_event(409): eth8: Disassoc 8C:B8:4A:4C:FA:2B, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8)
Feb 2 15:27:21 roamast: determine candidate node [40:B0:76:2C:5A:60](rssi: -42dbm) for client [8C:B8:4A:4C:FA:2B](rssi: -74dbm) to roam
Feb 2 15:51:11 wlceventd: wlceventd_proc_event(427): eth8: Auth 8C:B8:4A:4C:FA:2B, status: 0, reason: d11 RC reserved (0)
Feb 2 15:51:11 wlceventd: wlceventd_proc_event(455): eth8: Assoc 8C:B8:4A:4C:FA:2B, status: 0, reason: d11 RC reserved (0)
Feb 2 15:51:32 wlceventd: wlceventd_proc_event(409): eth8: Disassoc 8C:B8:4A:4C:FA:2B, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8)
Feb 2 15:51:32 wlceventd: wlceventd_proc_event(427): eth7: Auth 8C:B8:4A:4C:FA:2B, status: 0, reason: d11 RC reserved (0)
Feb 2 15:51:32 wlceventd: wlceventd_proc_event(455): eth7: Assoc 8C:B8:4A:4C:FA:2B, status: 0, reason: d11 RC reserved (0)
Feb 2 16:24:06 roamast: determine candidate node [40:B0:76:2C:5A:60](rssi: -42dbm) for client [8C:B8:4A:4C:FA:2B](rssi: -73dbm) to roam
Feb 2 16:46:06 roamast: determine candidate node [40:B0:76:2C:5A:60](rssi: -38dbm) for client [8C:B8:4A:4C:FA:2B](rssi: -72dbm) to roam
Feb 2 16:46:51 roamast: determine candidate node [40:B0:76:2C:5A:60](rssi: -40dbm) for client [8C:B8:4A:4C:FA:2B](rssi: -73dbm) to roam
Feb 2 16:47:21 wlceventd: wlceventd_proc_event(409): eth7: Disassoc 8C:B8:4A:4C:FA:2B, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8)
Feb 2 17:33:03 kernel: eth4 (Ext switch port: 3) (Logical Port: 11) (phyId: b) Link UP at 100 mbps full duplex
Feb 2 17:33:15 kernel: eth4 (Ext switch port: 3) (Logical Port: 11) (phyId: b) Link DOWN.
Feb 2 17:33:18 kernel: eth4 (Ext switch port: 3) (Logical Port: 11) (phyId: b) Link UP at 1000 mbps full duplex
Feb 2 17:51:36 wlceventd: wlceventd_proc_event(427): eth8: Auth 8C:B8:4A:4C:FA:2B, status: 0, reason: d11 RC reserved (0)
Feb 2 17:51:36 wlceventd: wlceventd_proc_event(455): eth8: Assoc 8C:B8:4A:4C:FA:2B, status: 0, reason: d11 RC reserved (0)
Feb 2 17:51:47 wlceventd: wlceventd_proc_event(409): eth8: Disassoc 8C:B8:4A:4C:FA:2B, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8)
Feb 2 18:02:06 miniupnpd[1521]: upnp_event_process_notify: connect(192.168.1.3:2869): Connection timed out
Feb 2 18:02:11 miniupnpd[1521]: upnp_event_process_notify: connect(192.168.1.3:2869): Connection timed out
Feb 2 19:16:35 ntp: start NTP update
Feb 2 19:29:19 wlceventd: wlceventd_proc_event(427): eth8: Auth 8C:B8:4A:4C:FA:2B, status: 0, reason: d11 RC reserved (0)
Feb 2 19:29:19 wlceventd: wlceventd_proc_event(455): eth8: Assoc 8C:B8:4A:4C:FA:2B, status: 0, reason: d11 RC reserved (0)
Feb 2 19:29:41 wlceventd: wlceventd_proc_event(409): eth8: Disassoc 8C:B8:4A:4C:FA:2B, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8)
Feb 2 19:29:41 wlceventd: wlceventd_proc_event(427): eth7: Auth 8C:B8:4A:4C:FA:2B, status: 0, reason: d11 RC reserved (0)
Feb 2 19:29:41 wlceventd: wlceventd_proc_event(455): eth7: Assoc 8C:B8:4A:4C:FA:2B, status: 0, reason: d11 RC reserved (0)
Feb 2 19:51:42 roamast: determine candidate node [40:B0:76:2C:5A:60](rssi: -32dbm) for client [8C:B8:4A:4C:FA:2B](rssi: -71dbm) to roam
Feb 2 19:52:42 roamast: determine candidate node [40:B0:76:2C:5A:60](rssi: -35dbm) for client [8C:B8:4A:4C:FA:2B](rssi: -71dbm) to roam
Feb 2 19:59:02 roamast: determine candidate node [40:B0:76:2C:5A:60](rssi: -34dbm) for client [8C:B8:4A:4C:FA:2B](rssi: -71dbm) to roam
Feb 2 20:01:22 roamast: determine candidate node [40:B0:76:2C:5A:60](rssi: -33dbm) for client [8C:B8:4A:4C:FA:2B](rssi: -71dbm) to roam
Feb 2 20:08:10 kernel: SHN Release Version: 2.0.1 0679c74
Feb 2 20:08:10 kernel: UDB Core Version: 0.2.18
Feb 2 20:08:10 kernel: sizeof forward pkt param = 280
Feb 2 20:08:10 BWDPI: fun bitmap = 3
Feb 2 20:08:21 BWDPI: force to flush flowcache entries
Feb 2 20:08:21 BWDPI: rollback fc
Feb 2 20:08:21 nat: apply nat rules (/tmp/nat_rules_eth0_eth0)
Feb 2 20:08:29 kernel: SHN Release Version: 2.0.1 0679c74
Feb 2 20:08:29 kernel: UDB Core Version: 0.2.18
Feb 2 20:08:29 kernel: sizeof forward pkt param = 280
Feb 2 20:08:29 BWDPI: fun bitmap = 3
Feb 2 20:08:40 BWDPI: force to flush flowcache entries
Feb 2 20:08:41 BWDPI: rollback fc
Feb 2 20:08:41 nat: apply nat rules (/tmp/nat_rules_eth0_eth0)
Feb 2 20:09:16 kernel: SHN Release Version: 2.0.1 0679c74
Feb 2 20:09:16 kernel: UDB Core Version: 0.2.18
Feb 2 20:09:16 kernel: sizeof forward pkt param = 280
Feb 2 20:09:16 BWDPI: fun bitmap = 3
Feb 2 20:09:27 BWDPI: force to flush flowcache entries
Feb 2 20:09:27 BWDPI: rollback fc
Feb 2 20:09:27 nat: apply nat rules (/tmp/nat_rules_eth0_eth0)
Feb 2 20:43:07 roamast: determine candidate node [40:B0:76:2C:5A:60](rssi: -39dbm) for client [8C:B8:4A:4C:FA:2B](rssi: -72dbm) to roam
Feb 2 20:48:52 roamast: determine candidate node [40:B0:76:2C:5A:60](rssi: -27dbm) for client [8C:B8:4A:4C:FA:2B](rssi: -77dbm) to roam
Mesh: Asus Rt-AC88U
