Asus Ax56U
MrBenz
Hi ,
Can Anybody help me to configure iptv for MEO - Portugal in this router ?
I don't no the number i put in the ports to work
Thanks a lot for your help
but i can't find the config to my provider
maybe Merlin put the meo configuration in the stable release i hope
You have an example in that link try and se if it is working.
My Other router Ac68u works very well but it's broken
i need to bought another one and a bought this model Ax56u
Are you able to copy the working settings from the Ac68u?
I'm asking the merlin developer for help In order to put MEO iptv settings ... on all asus routers you have
I don't found the mail to send a message to merlin developer to ask and help in this product !!
You can "tag" merlin and ask here on snbforum.
@MrBenz all you need to do is put an '@' symbol in front of the name you want (i.e. RMerlin). :)
You're welcome, but be more considerate of RMerlin's time; be more specific in your request (he shouldn't need to read the whole thread...). :)
I only want the config of other asus of iptv MEO to put in my router rt-Ax56u
In this moment i change my firmware to merlin beta ... but nothing
I will wait for the stable release
Thanks to All
@RMerlin
Thanks to All
@RMerlin
Have you tried this: ?
My Router don't have that ... this is my problem
The only change i have it's do it manual ... but i don't no the number of the port and the configuration
If the router doesn't offer the Meo profile then it means it's not supported by that model. Not all models do.
You will have to contact Asus's tech support about this, there's nothing we can do to help you.
