Asus AX86U Pro - Guest Network losing internet
gabzprime
I'm using stock firmware. I noticed that the second guest network loses internet connection on the laptop but not on mobile phones. I haven't checked the first guest network. Things resolve themselves when I restart.
Anyone encountered this? Is there any setting that will prevent this from happening?
firmware version:3.0.0.6.102_34336
What Guest Network Pro preset are you using for the Guest Networks? And how is that preset configured? Do you have WiFi Scheduling enabled on the preset?
Have you checked the router log to see if anything unusual is happening around the time the laptop looses internet on the second guest network?
Do you have any sort of Parental Controls Time Scheduling enabled? If using the Asus router app, check the app in addition to checking the router GUI.
Troubleshoot the laptop.
OE
Its a customized network. There are no schedules whatsoever.
