sucka
Hello,
i have an axe11000 and i have a wifi problem, i have tested the problem using a windows laptop with an ax211 card and with 2 macbook pro one with m1 and one with m2, and with an iphone 12 pro max.
I have tested the following firmware versions:
Asus stock:
3.0.0.4.388.21224
3.0.0.4.388.20499
3.0.0.4.386.49675
3.0.0.4.386.47875
Asus Merlin:
388.2 alpha 1
388.1
Tested everything from stock config to different combinations of everything from smart connect, beamforming, mu-mimo and all settings from professional tab off or on and all channels and all 3 wifi frequencies 2.4, 5 and 6ghz.
I have a gigabyte download and upload internet connection and on lan everything is working perfectly.
Now that i have wrote what is the testing specs, the problem is, i have very low speed for download only, even uploads are not stellar but downloads rarely get to even 100mbps, it wasn't like that about 3 months ago when i have bought the router coming from an ax11000 and did the setup and tests.
The weird thing is on speedtest latency increases allot, and as the latency increases, the speed decreases, maybe it starts with a couple of hundred mbps and quickly descends, on speedtest.net on mobile i can even gen to about 1500 download latency but still around 40-60mbps download only.
The only setting that did some difference was disabling smart connect because when testing with the ax211 and disabling smart connect even though i have tested with it on or off and i was either on 5 or 6ghz, but with it off, it tries to stay to at least 100mbps and stays a little longer at higher speeds, with it on, quickly descends to sub 100.
Cpu usage is very low and nothing weird is happening on the router side, even the log doesen't seem to have anything weird in it, on lan i get @920-937mbps download and upload every time.
The problem is so weird only a video i think can show how weird it is, a test from 2 meters away on my macbook pro with m2 cpu.
Do you think it may be a hardware fault or is anyone else experiencing something similar?
trying to find out more before i send it to repair, maybe it is something that is known, maybe a software bug that i triggered somehow, i discovered it today and clean installed all those firmware versions and tried every combination possible, but maybe something slipped and i don't know about.
P.S. tried with all firmwares stock config, just after exiting the wizard, and in the same place with the same devices the ax11000 is working ok.
Asus stock:
3.0.0.4.388.21224
3.0.0.4.388.20499
3.0.0.4.386.49675
3.0.0.4.386.47875
Asus Merlin:
388.2 alpha 1
388.1
