Asus AXE1600 3.0.0.6.102_36382 broken dual wan
Bhoot®
Hey,
Asus AXE1600, upgraded to recently released 3.0.0.6.102_36382 firmware.
WAN links became unstable, so full reset / restored entire network.
WAN links - stable again.
Issue. Dual WAN no longer works. In WAN > Internet Connection tab > WAN Index > Want Type > if I select 10G Ethernet or 2.5GB WAN. The SAME config is being applied to both.
Previously, you clicked on drop down, at the options would load > enter settings > done.
Now > click dropdown > no change. Whatever you enter is set for both WAN links.
I then tried 'Add Profile' but that is also broken. If I create multiple profiles, the dropdown box in the profile page does nothing. There is no way to bind a profile to a link = same above - same config on WAN links. Appreciate any help, tried searching forum, YouTube, Reddit - did not find anything to help.
Each WAN link set a primary link + right WAN config does work > WAN do work when configured properly.
Hoping someone can point me in the right direction. Thank you.
