garett_09
Hi everyone!
I just upgraded my router from AX11000 to the new BE88U and I have enabled the BE88U as my main node. I tried using AI Mesh wireless backhaul since i do not have any ability to do it wired, i tried to do them wirelessly. Upon successfully pairing them, the AX11000 frequently drops from my network every 30 seconds making the AX11000 useless as a secondary node. I am running the latest merlin firmware on BE88u Current Version : 3006.102.3 and on AX11000 Current Version : 3.0.0.4.388_24394-gb70bc6c
Here are the logs
Feb 17 07:53:37 hostapd: wl0.1: STA 7c:10:c9:a5:36:81 IEEE 802.11: associated (aid 2)
Feb 17 07:53:37 kernel: SBF: dhd0: INIT [7c:10:c9:a5:36:81] ID 65535 BFW 65535 THRSH 2048
Feb 17 07:53:37 wlceventd: wlceventd_proc_event(722): wl0.1: Assoc 7C:10:C9:A5:36:81, status: Successful (0), rssi:-39
Feb 17 07:53:38 hostapd: wl0.1: STA 7c:10:c9:a5:36:81 IEEE 802.11: disassociated
Feb 17 07:53:38 wlceventd: wlceventd_proc_event(662): wl0.1: Disassoc 7C:10:C9:A5:36:81, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
Feb 17 07:53:38 wlceventd: wlceventd_proc_event(645): wl0.1: Deauth_ind 7C:10:C9:A5:36:81, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3), rssi:0
Feb 17 07:54:06 wlceventd: wlceventd_proc_event(685): wl0.1: Auth 7C:10:C9:A5:36:81, status: Successful (0), rssi:-31
Feb 17 07:54:06 hostapd: wl0.1: STA 7c:10:c9:a5:36:81 IEEE 802.11: associated (aid 2)
Feb 17 07:54:06 kernel: SBF: dhd0: INIT [7c:10:c9:a5:36:81] ID 65535 BFW 65535 THRSH 2048
Feb 17 07:54:06 wlceventd: wlceventd_proc_event(722): wl0.1: Assoc 7C:10:C9:A5:36:81, status: Successful (0), rssi:-33
Feb 17 07:54:07 hostapd: wl0.1: STA 7c:10:c9:a5:36:81 RADIUS: starting accounting session E0B8DE2F06215727
Feb 17 07:54:07 hostapd: wl0.1: STA 7c:10:c9:a5:36:81 WPA: pairwise key handshake completed (RSN)
Feb 17 07:54:07 kernel: Assigning idx[152] for wds0.1.1
Feb 17 07:54:07 kernel: wfd_registerdevice Successfully registered dev wds0.1.1 ifidx 2 wfd_idx 0
Feb 17 07:54:07 kernel: Register interface [wds0.1.1] MAC: 8a:28:aa:29:f6:51
Feb 17 07:54:07 kernel: SBF: dhd0: INIT [7c:10:c9:a5:36:81] ID 65535 BFW 65535 THRSH 2048
Feb 17 07:54:07 kernel: br0: port 13(wds0.1.1) entered blocking state
Feb 17 07:54:07 kernel: br0: port 13(wds0.1.1) entered disabled state
Here's another log of the AX11000 connecting to 5GHZ.
Feb 17 07:58:40 kernel: ^[[0;31mdhd_pktfwd_lut_lkup: dhd_pktfwd_lut_lkup: pool 0 and unit 15 mismatched
Feb 17 07:58:40 kernel: ^[[0m
Feb 17 07:58:40 kernel: Freeing devid[2219] for wds0.1.1
Feb 17 07:58:40 kernel: device wds0.1.1 left promiscuous mode
Feb 17 07:58:40 kernel: br0: port 13(wds0.1.1) entered disabled state
Feb 17 07:58:40 kernel: wfd_unregisterdevice Successfully unregistered ifidx 2 wfd_idx 1
Feb 17 07:58:40 kernel: br0: port 16(wds1.1.1) entered disabled state
Feb 17 07:58:40 kernel: ^[[0;31mdhd_pktfwd_lut_lkup: dhd_pktfwd_lut_lkup: pool 1 and unit 15 mismatched
Feb 17 07:58:40 kernel: Freeing devid[2220] for wds1.1.1
Feb 17 07:58:40 kernel: device wds1.1.1 left promiscuous mode
I have also enabled the 5-2GHZ FIRST option in backhaul mode.
Thanks everyone!
Here are the logs
Thanks everyone!
